You are wasting your time with most of these replies. Mine boiled over doing the same exact thing. Switched to a Phenolic 1" spacer under the carb. Still boiled over. Adjusted the floats to an exact science, and it helped some, but each time I parked the vehicle, I noticed a fuel smell. I would lift my air cleaner and the secondaries would be leaking and steaming from the carb.
If you are running a 195 degree thermostat, you'll notice that your secondaries boil over after you are parked with the engine off. Thats because the engine is still heating up, but your fans aren't cooling the engine anymore. Mine would begin to boil around 210 degrees. You might be able to try wiring in your fans to run to full power instead of switched with a variable thermostat on the fans to shut off at 185. ???????
Other than that, I am running an Engine driven fan, and the best I could do was switch to a 180 deg. thermostat.
Problem solved. Mine doesn't boil over anymore. When parked, it never gets above 195.
