Belgian User
I have 2.8V6 Tbi.
It idles bad ( after I changed the sparkplugs because it didn't idle at all anymore ) , can't seem to find leaks.
It also smokes when I accelerate or even when it's iddling. It's not oil and / or blue smoke. Really looks like fuel that doesn't get burned. Ok I might change the sparkplugwires to be sure but I don't think that's the problem. My Blazer can also run on propane and it does not seem to have problems when it does run on that.
So I do think somethings wrong with the fuel supply somehow. Any suggestions ?
Maybe later.
Does it run on Propane?
Belgian User
Yes, seems to have no problems in that case. But I want the original fuel-system to be ok, just in case I run out of propane before I reach a gas-station where they sell it.
As soon as I switch to propane ( and original fuel-supply get's switched off ), rpm goes up and it's running fine.
overthinker extraordinar
wild ass guess, timing.
Propane has a higher octane and could run okay with advanced timing. Gas, well it would cough and sputter a bit if it was too advanced.
Like I said, WAG
good luck
mark
I'm curious as I don't know the technical specifics of the system for propane in conjunction with gas, but is there a different computer and injector system for that, or does the propane use the same ecm and injectors?
sorry, I don't know. I am guessing at the timing thing too.
Belgian User
Checked the idle, maybe one degree off. That's not going to be the problem I guess.
About running on propane, it uses the same ECM. All what happens is that fuel supply is cut off and propane is injected before the throttle body.
I am starting to think I have a melted or clogged cat ? Melted because running on propane is a lot hotter. It's throwing also two codes: to rich and to lean mixture ....
About this Discussion
4 Participants
SimonV
S-10 Forum
Full Forum Listing
