Who makes the cheapest complete test pipe for my exact needs?
I had no troubles getting the shop to pull the cat of my 92 talon TSI AWD but i cant find a shop that will do it on my dyme...
I have no idea why either ...makes no sense.
THANKS ALL
Powered by Xtant
i'm not sure about a '96, but on my '97 s-dime there is an air sensor located between the cat and the muffler. if you remove the cat then the service light comes on and causes the PCM to screw up the air/fuel mixture or something like that
I've heard that you can get a simulator to stick on the sensor after you remove the cat but no for sure
White Shark
I have one from Casper Electronics, it works great. It was $45.
Eddie
If I am not wrong . the simulator is just a resistor that makes the PCM believe the O2 is still there , hot , and that O2 is acceptable.
I saw something in a tech section about it here or at another S10 site.
