Tonight i was messing around with a friend on the highway and i steped on the gas and snapped my u-joint,broke the yoke,bent the driveshaft,and the trany makes a bad noise too....idk if its because the drive shaft is not in it tho..?? my problem is i have a mono leaf set up bagged with a 4 inch angled block... i think this happend because of the pinion angle being off... is there a way to fix this with the mono leaf setup so its not so bad... if not i am going to just get a 4-link so i can adjust the pinion angle so it will be right...i am looking at this one from SD looks like most of it bolts on except on to the axle... with this 4link will i have to take my bed off to install it???? sorry for the long post... here is a picture of the 4 link i want... if anyone has one of these let me know how they work... thank you very much .....
