1 - 10 of 10 Posts
i am looking to buy another system what do u guys think of this setup
hifonics z600
2 x 150 Watts @ 4 Ohms
2 x 300 Watts @ 2 Ohms
1 x 600 Watts @ 4 Ohms
New Hifonics Twentieth Anniversary Heat Sink Design
Illuminated Hifonics Badge
Illuminated Maxxsonics "M"
Bass Remote with Blue LED Power On & Diagnostic Indicator included (except ZX8000)
Ultra-Fi MOSFETS
Zeus EVXP (Exponential Vari-Power Supply)
SPC - Simpatico Coil Design
HSMD - Hifonics Surface Mount Design
Fully Adjustable
4 Gauge Power Connectors
Class A/B Operation (Except Z1000D - D Class Digital)
Maxi-Fuse
Gold Plated Inputs and Outputs
4/2 Ohm Stable
Bass Remote Control With Diagnostic LEDs Inc
or crunch v2600
2 x 300 Watts 4 Ohms
2 x 400 Watts @ 2 Ohms
1 x 800 Watts @ 4 Ohms
V-Drive Blue Anodized Inverted Heat Sink Design
Dual VU Metering System with
Acrylic Lens
Mesh Grille Ventilation Design
Chrome Heat Sink Cover
PWM Mosfet Power Supply
Fully Bridgeable Design
Blue High Quality PCB Design
Ultra—Drive High Speed Mosfet Output Devices
Class AB Operation
On Board Tru-Spec Capacitors
Premium Hand Wound Torroid
Separate Bass and Treble Controls
Bass/Treble On/Off Switch
HP (High Pass) from 10 Hz to 30 KHz Adjustable Crossover Network with Subsonic Filter
HP/LP/Flat Select Switch
LP (Low Pass) from 40 Hz to 4 KHz Adjustable Crossover Network
Gold Plated RCA Line Input
Gold Plated RCA Line Output for Amplifier Daisy Chaining
Internal Protection—Thermal, Short Circuit, Overload Circuitry
Red Protection LED
Green "On"LED
with 2 12" audiobahn aw1251t
12" High Performance Subwoofer
45 OZ. Strontium Magnet
2" 4 Layer Black Aluminum Voice Coil
400W RMS Power Handling Per Sub
800W RMS Power Handling Per Pair!
30Hz - 1kHz Freq. Response
91.1dB Efficiency
Bumped & Vented Polished T-Yoke
Poly Coated 2 Layer Non Pressed Paper Cone
Lug Lock Terminals
Dual 4Ù Voice Coils Per Sub
1Ù or 2Ù or 4Ù or 2Ù Stereo Operation
Rubber Gasket & Magnet Mesh Cover
5" Mounting Depth
thanks for all ur input
I like the audiobahn, i have a pair and will never change. What ohm are your subs and i had a hifonics z400 and wasn't impressed with it at all. Never delt with crutch so i don't know about that. Keep in mind it is better to overpower them than underpower them. I am overpowering my subs by like 150 watts.
later
Always Dreamin Big
Hifonics, all the way. It's rated as 600 rms and will do probably 600-650 rms. The Crunch is rated as 800 rms and will do probably 400-500 rms at best. I had a V-300 before, it was rated to push 350 rms. After playing with many different amps on the same sub/box setup I would guess that I would be lucky to have been getting 200 rms from the Crunch. They are cheap stuff (but real reliable, mine got ran at 2 ohm mono for many many months by the kid I sold it to, now it still kicking to this day, about 5 years later).
so if i maybe went with a crunch 2800
2 x 350 Watts 4 Ohms
2 x 500W @ 2 Ohms
1 x 1000 @ 4 Ohms
Acrylic Lens
Class AB Operation
Red Protection LED
Green "On"LED
i had a 600 watt crunch amp running two 10" mtx thunder 6000
i was pleased with the price and performance
Always Dreamin Big
I believe they are owned by the same company but manufactuerd by their own companies.
For example: American Pro, Teknique, and Volfenhag are made by the same company, and all their products are the sam but tagged differently.
Orion, Precision Power, Directed Audio, Viper, a/d/s and about 10 other companies are all owned by one big company (Directed Electronics) but left to build their own stuff.
BLING BLING!
i was suprised when i clicked in here that i saw good brands, i was expecting another crutchfield system being put together smart thinking sctt. hifonics and crunch r both owned by maxxsonics, but they are made by 2 different. crunch is pretty much a generic hifonics,but go for the hifonics, u wont be dissapointed.
1 - 10 of 10 Posts
