soLoRed
Ok well i have my new truck , 86 s15 ext cab, ok well on the roof theres that stock carpet type material that goes from the front to the back... can i just tweed on that? or should i remove the shit and then tweed on the metal?? and will the adhesive stick to dynomat?? and wat little tips can u give me while im tweeding... any help will be great oh and for design wat size of foam should i get ?? (hight wize) thanks guys
-db
Drop N Destroy
lay it over the carpet material im pretty sure that the adhesive glue will stick to the dynomat i know you are supposed to use sculpting foam im not sure what size though i dont have designs in mine but use 3m super 77 adhesive glue. And on the headliner alot of people use the stronger adhesive than the super 77 but i used the 77on mine held up good so far just be patient when you are tweeding keep it stretched take your time hope it turns out good man
