1 - 2 of 2 Posts
I just bought a 93 s-10 and the turning signal is broken. The lever next to the steering wheel just rests in the down position. Im pretty sure all the wiring is correct because the wipers and windshield cleaning spray still work. When I try to move the lever up it just falls back to the original position and the turning signals dont even flash. I tried to remove the covering from behind the steering wheel in order to access the broken lever but the parking brake seems to anchor the panel in. Anyone have any tips or suggestions?
i saw what you did there!
either broken switch or screw missing that holds the metal piece that connects the lever to the switch
youll have to take the wheel off and the lock plate off to see what happened exactly
1 - 2 of 2 Posts
