Ive got a set of 3 inch blocks I want to cut down to 2 inch blocks. After installing my drop leafs with the 3 inch blocks its bottoming out constantly even with the c notch. Question is what would be the best way to cut these down. Im thinking measuring alot very precisely and cutting with a cut off wheel.
Registered Hoosier
Too much trouble IMHO. Just buy new, then sell your 3" on CL.
Actually just found some 2 inch blocks in the garage. They look alot different though. I think I had them on my toyota as lift blocks. Might try these
I did this to a set of 4" blocks, I cut 3/4" off of them. Before cutting I measured one and it was not true (measured on the same place of each side.) I used a band saw to cut them but a chop saw (which I now have) would have done the trick much better.
Those toyota blocks might be to narrow for you.
keep on keepin on...
have a set of 2" belltech blocks for 20 if you want em. had them on my truck for about 6 months
