Fever for the Flava
i have a 94 s-10 with a 4.3, the back up lights and turn signal lights on the grill will not work. i just bought it about two months ago and its always been like that. i've checked the bulbs and the fuses in the cab, and they are both good. what should i do?:confused: is anyone else having this problem?
Got Stones????
Birmingham?
Dude you from Bama right? Im from Greenville right below Montgomery. Well about your lights I had a similar problem. My rear tail light flasher was bad which cause my front signals and back up lights not to work. I changed the bulb and the problem was solved. Not sure if it will solve your problem though.
Fever for the Flava
ive only changed the back up ones, where do u check the fuses under the hood?
Fever for the Flava
ok now the turn signals work :), but the back up lights still dont work?, ive replaced every burnt out light of it.
Fever for the Flava
as of now, the back up lights and the 3rd brake light want work, is there something i can do, or should i take it to the dealership?
