Replaced plugs and wires, firing order is definitely correct. Replaced the distributor cap as well. Only getting backfire and won’t turn over. Any suggestions?
Something is win the wrong order if it ran before. What does resolved the distributor cap mean?
Awww..you ain't got shit!
Did you verify the rotor is pointing at #1? You may also be 180 degrees out. If it ran before, likely this is your issue.
