I am looking at this rack setup.
www.trzmotorsports.com
Before anyone asks whats wrong with the proven setup. I cut my frame off in front of the A arms to shorten the overall length and reduce frontend weight early on.
Ok this has been asked tons before so like a good boy I searched for a few hours.
While searching I have seen lots of recomendations. But I found very little actual installs and even less about how to install it.
Get on youtube and they all show setting up the rack and welding it in. All pretty basic and it looks like a nice kit.
But almost all are vague on the actual tie rod angles and if they had any bump steer after the install.
So before I order the kit I would like to get some first hand experence.
I have a 94 that had a 2.2, 5 speed standard cab. Lots of mods and about all that is still stock suspension /steering wise is the upper and lower control arms and I am using stock spindles.
I am within 100lbs of my final front end weight so I do not see any significant change in setup from now to when the thing gets paint.
I just need some insight from any actual installs with any issues that came up or things you would do differently. Maybe a few tips on where you want the arms as it relates to suspension travel. Pictures or links to a build thread or a possible writeup I missed.
Manual Rack and Pinion Conversion Kit (S10 / Blazer)
Custom Narrowed Pinto Style Manual Rack specific for the S10 / Blazer Adjustable Bump Steer / Tie Rod Kit Rack Clamp and Rack Mount Plate 3/4″ Chrome-Moly Steering Shaft and Shaft Brace 3 Chrome-Moly U-Joints (One 9/16″ – 26 spline to 3/4″ joint + Two 3/4″ x 3/4″ smooth joints) Welding Required...
