Give me 3 yrs...
its a 98 2.2l reg cab spd just hit 100k... im pretty sure its just the classic clogged/rattling cat but lemme know if u guys think its anything else...
SYMPTOMS (sp)
loud rattle at low rps
rich unburnt fuel smell sometimes at idle/low rps
startup it wants to die after i clutch out in 1st gear, i hafta clutch back in and rev it a tad to keep it from dieing.
not truck totalling problem but if its the cat i wanna just cut to sob off and straight pipe it, also wats the sensor in front of the cat? how do u check it? i looked briefly at it and it looks to be bung welded in.... wat other things could be causing the problem, ive noticed a slight decrease in mpg especially city driving. lemme know guys wat all i should check/replace on this thing
Give me 3 yrs...
yea.. sounds like the packing inside has broken loose and is rattling . The sensor in front of the cat is an O2 sensor which you will want to keep.
that why it smells like its running rich? and almost dieing?
355 member
could it be the inch and a half of water you picked up coming through PA this weekend :haha:
All of your symptoms could be caused by a clogged/bad cat, your probably not going to be able to tell much else until you replace it. Hit the cat with a rubber mallet if it sounds like the insides are rattleing around, its just like biggeris better said, the inside broke loose
355 member
oh man, wrong person. just ignore me
Give me 3 yrs...
Discussion Starter #8
ya ive called gm and my cat (over 80k) and my wiper motors (incorrect vin for replacement) were denied, soo ok ill change the cat out n we will see how it goes
