Ok I need some help! I move the stuff under my hood the computer fuse box and moved the battery in the back. I run a power cable from the back to the fuse that was under the battery, that also goes straight across to the starter. Now when I try to crank the truck it just clicks like the battery is dead but it is hot. Do I need to run a wire straight from the battery to starter. Any idea on what I need to do.
ps this is on a 98 s-10 2.2:wtf:
I have no clue what u just said but if u moved ure fuse box, check the igntion fuse (50 amp) under the hood, and check to make sure u didnt pull any wires out of the starter relay in the fuse box...ull have to take the panel off the bottom of the fuse box. And make sure u hooked up the ground in the back and re grounded the ground that was in the front.
It is getting power to everything cause the starter is clicking but it won't spin. The battery is in the bed do I need to run a wire straight to the battery.:dunno:
