I've got a 1989 S10 2.5 TBI 5 speed with 86,000 miles.
About a month ago when it started turning cold, my truck wouldn't start. I had it towed to the dealer and diagnose it. They said it was the fuel pump. Dad and I changed out the pump but it still wouldn't start when it turned cold. We changed the ECM in the distributor. Same problem. Changed the ignition switch on the steering column. Same problem.
If you cycle the fuel pump 3 or 4 times the truck might start even if it is real cold outside. Or if you just pour a little fuel down the intake it will start right up.
I was wondering if anyone else has experienced the same problem.
We are almost positive that it is fuel related. We are thinking now that it is the injector. Is there any test we can do to see if the injector is bad? Is there anything else that we need to check?
Any help or opinions will be greatly appreciated.
~ Mongo
~ Mongo
