92 2wd 4.3 tbi
This is my uncles truck. when he starts it up to warm it will idle fine for a few minutes, then it will slow down till it chugs and almost dies, then speeds way up and roars the piss out of it self. it will do this for a while then it will level out and idle right.
do any of you guys have any suggestions.
any help will be appreciated thanks
josh
PCV valve
My truck was doing the exact same thing, but not to the point that it would kill itself. I got a repair manual for my truck and it said to check the PCV valve and it checked out fine. But the hose that it was hooked up to had a crack in it at an elbow causing a vacuum leak. I went to Advance auto parts and got a hose from thier "emissions isle" and it runs like a champ now. I got the truck with right at 100000 miles on the odo. :afro:
Clean N' Dark
IAC Valve (Idle Air Control)
It's defective. Swap it out and it should be fine.
ok thanks
