louder than you
i have a trouble code coming up it says miss in the #1 cylinder. I have a slight puffing sound thru my exast. If i clear the code it will trip the check engine light by just idling in the driveway. My friend says its a leaky injector. what do you all think and if its a leaky injector how hard is that to fix.
loco hombre
What year and engine? Fixing leaky fuel injection on a CPI is common but different than later years :)
Dumb question... have you tried the obvious stuff and replaced the spark plug and inspected the wire?
louder than you
yes i replaced cap rotor plugs wires o2 sensor maf and map sensors. the truck set for 2 years. its a 1997 with a v6. it starts really well accelerates good and never back fires. i just have this last trouble code and the puffing sound thru the exast.
thanks
louder than you
bump
im changing the fuels injector tomarrow to see if that helps
