I have a 91 sonoma that I'm putting a lightly built small block in and i plan to use a tremec t-5 out of an 85 s-10. does anybody have suggestions about a clutch and flywheel combo that would work with that. looking for an afordable option but any tips would be appreciated.
This is the syty specific section. You will get more help from areas that have something to do with your topic. Try the V8 section or the Transmission section.
i saw what you did there!
most affordable would be an OEM replacement
whatever size the bellhousing is will determine the application flywheel and clutch size to use, that will fit inside the housing
id use a 85 camaro or s10 clutch, whatever diameter is meant for that bellhousing
4.3L s10 or v8 f body
or if the engine youre using is an 86 up then youll have to use an 86 up application flywheel since the crank pattern changed that year to one piece RMS pattern but you probably already know all this
have fun
