1997 GMC Jimmy 2dr 2wd
Hey y'all, I have a few questions on transmission options for my truck. I was considering getting my 4L60 ran through and some parts replaced, but then I learned that I hate the gearing ratios in it, I'm also thinking about either swapping in a T5 or T56 manual or getting my 4L60 beefed up and get the ratios changed. I also am considering changing the 3.42 differential gearing to a 3.73. What are your guys' inputs? Edit#1: I basically drive to work and school which are both here in town and occasionally to my girlfriend's house which is a drive to the mountains, so using my brain I can only assume that a lower gear ratio would be better and have less wear on several parts, and get better fuel economy in the city, or am I completely wrong?
Randy
Sonnax does make a 2.84 front planet for the 4L60E. It costs approximately $800 though. Most people won't pop the $ for it. I had 2000 4x4 Blazer LT with 3.73 posi's front and rear. It was fun to drive.
Engineer
2003 S10 4.3L 4wd Crew Cab
A lower gear ratio will get you better mileage at speed, but will wear on your tranny slight more during acceleration.
2000 Blazer SAS
That may be true if you're talking about a numerically lower gear ratio, but going from 3.42 to 3.73 would probably have the opposite effect. IMO, though, it's not enough of a change to warrant the trouble and the expense.
