Will a 4l60e transmission out of a 1995 2wd. full size Chevy truck. With a automatic transmission Go into a 1995 s10 automatic transmission 2wd with a 4.3 litter engine. Extended cab
If both are actually 1995 units it should be a direct swap. The only real difference I can think of is the Full Size truck has a stamped steel dust cover and the S10 will have a aluminum one with 4 bolts & the ears cut off. you can cut the ears off the full sized truck with a Sawzall...Will a 4l60e transmission out of a 1995 2wd. full size Chevy truck. With a automatic transmission Go into a 1995 s10 automatic transmission 2wd with a 4.3 litter engine. Extended cab
