2nd Civ Div
My transmission grinds in 3/4/5th AFTER I shift to the point where I cant barely accelerate. Safe to say I need a new transmission?
It's "Neanderthal"
Does the case have enough fluid?
2nd Civ Div
Yes (there is transmission fluid sprayed all on the bottom of my truck from the drive from Virginia from me picking it up though.
9" strait pipes...
call me a genius but maybe this is a clue?
have you actually checked the level and verified?
2nd Civ Div
Yes I checked the level even after that. I was assuming there was a crack somewhere or a break in one of the lines because of all the fluid.
It's "Neanderthal"
One of the lines? This is a standard transmission, right?
A manual has no "lines".
Can you shift into reverse without grinding? If you have no grinding here then the transmission is likely the problem.
A grinding transmission is most often the clutch not releasing, usually most noticeable in the lower gears and reverse. So if the clutch is releasing then the transmission is the problem.
