1 - 2 of 2 Posts
1999 S10 with Gen I 350 W/Tri Power and Muncie M20 swap still in progress.
Hi to all I'm a newbie here. I have a 99 S10 with a 1969 4 bolt main 350 and Offenhauser Tri power set up in the truck now.. I replaced the automatic transmission with a M20 Muncie what length drive shaft do I need to use to make this work the automatic drive is to short. Thanks for the help
Randy
This not something that everybody will know off hand. it's a custom set up. Your going to have to mock up the driveshaft you have and measure how much longer it will need to be. center of u joint to center of the u joint location at the rear end. It's not hard but can be a bit intimidating at first. measure 3 times and have it built. A driveshaft shop can help with the the how to measure if needed.
Just keep in mind that the slip yoke must have 3/4"-1" slip before bottoming out on the output shaft.
1 - 2 of 2 Posts
