proflo'dS10 said:Depends which 4 banger you are talking about. If you are talking about the 2.5 Tech 4 that came in the 1st gens, the trans is the same pattern as a 2.8. If you are talking about the newer 2.2 transmissions, they have the same bolt pattern as the 4.3 and V8's. Hope this helps.
Thanks - that is exactly what we were trying to find out!proflo'dS10 said:Depends which 4 banger you are talking about. If you are talking about the 2.5 Tech 4 that came in the 1st gens, the trans is the same pattern as a 2.8. If you are talking about the newer 2.2 transmissions, they have the same bolt pattern as the 4.3 and V8's. Hope this helps.
