What is the difference in the 700-r4 and the 4l60-e transmissions? Im wanting to change the filter, fluid, and gasket on my 93 s-10. Is there a difference in the pans or can i look at the bolt pattern?
FatBoy
The trans are different atleast internally. The 700R4 is now the 4L60E. The 700 is completely non electronic. In 90 I believe it was renamed the 4L60 which is also non electronic i believe, but updated and then the 4L60E is electronically controled.
Mr. Clean
I don;t know too much about trannys, but wouldn't the computer controlled valvebody on the 4L60E do away with the TV/Kickdown cable used on the 700R4? That might be about the only way to tell.
if it days "turbo hydramatic" its the 700. or it will be stamped "4L60E" on the pan.
