1 - 20 of 32 Posts
the youngest has been
2.5 4 CYLINDER
auto 700r4
manual 4 speed T4
manual 5 speed T5
2.8
auto 700r4
manual 4 speed T4
manual 5 speed T5
4.3 up to 92
auto 700r4
manual nv3500, ive heard some got t5's but i dont know if thats true or not
4.3 in 93 and up
auto 4l60e
manual nv3500
2.2
auto 700r4
manual nv1500
typhoons came with 4l60 NOTICE the "e" is missing its the no computer controlled 4l60e, im not sure if the 700r4 and the 4l60e are the same but its possible they are
i got tired of the hey waht tranny do i have so hopefully my info is correct, im not to sure on the 2.5 auto tranny but if i remember correctly it should be a 700r4
and hopefully one of the mods will sticky this
and if anyone know i made a mistake please tell me i did this wright up rather quickly
-mark
all the ones ive seen have had an nv1500
can anyone else confirm this, if so we need to change the list
"factory freak"...
the 700-R4 and 4L60 are the same transmission. GM just re-named it, along with it`s other auto trannies with a new designation system around 1990-91.
actually there are a few slight differences, like the 700r4 used mechanical linkage to shift gears where as the 4l60 used a cable
for the most part they are the same but there are a few differences also
Resident Jackass
My 82 2.8 is backed up by a T-4C, not a T-4. There is a huge difference if you are ordering a rebuild kit. Just thought I would share that, because it cost me an extra week of down time, trying to correctly identify the trans and then get the correct kit.
Resident Jackass
tippmann243 said:
good to know,
what are the differences?
The main difference is the bearings for the input and output shaft. The T-4C uses roller bearings while the T-4 uses needle bearings, and they are totally different dimentions (diameter). I didn't get much past that as far as differences go. I wasn't going to pull my input and output shaft without the right parts for reassembly.
"factory freak"...
are you talking about the detent cable? all of them prior to the electronic trannys had a detent cable.
internally, the 700R4/4L60`s got minor upgrades constantly. but they were still the same basic tranny.
I think, he's talking about the gear selector and if he is, he's wrong there also. It depends on the shifter in the vehicle to determine, if it was cable controlled or linkage
Resident Jackass
tippmann243 said:
so they are still the same just some got a better version
Actually, the ball bearings are pretty stout. I'm not sure how the needle bearings work stacked up against them. The reason for the rebuild was that the synchronizers were worn. I have been told the T-4C is a Jeep transmission and that Chevy mix and matched parts in the first model year, but I have never taken the time to research it.
My 2000 2.2 has a 4l60e Auto.
Just had it rebuilt so I know ;)
... I hope ha ha
Discussion Starter #15
... I hope ha ha
yeah that was a typo on my part just wish i could edit my post
another mess up on my part for some reason i was thinking that all vehicles had the mechanical linkage but its only vehicles with colum shifter, it you had a floor shift like in a vet or camaro or so on they had a cable shifter
700R4 and 4L60 are the same tranny. The 4l60e is different.
3L30 - Automatic​
YEAR MAKE MODEL
92-95 Chevrolet Geo Tracker E 2WD
89-95 Chevrolet Geo Tracker J 4WD
94-95 Chevrolet/GMC Postal Chassis LLV
87-93 GMC Postal Chassis LLV
3T40 - Automatic​
YEAR MAKE MODEL
88-96 Buick Century
87-95 Buick Skylark
87-88 Buick Somerset
87-88 Cadillac Cimarron
88-95 Chevrolet Beretta
88-96 Chevrolet Corsica
87-01 Chevrolet Cavalier
88-89 Chevrolet Celebrity
90-93 Chevrolet Lumina
90-95 Chevrolet Lumina APV
92-95 Oldsmobile Achieva
91-93 Oldsmobile Cutlass
87-91 Oldsmobile Cutlass Calais
88-96 Oldsmobile Cutlass Ciera
87 Oldsmobile Firenza
90-94 Oldsmobile Silhouette
88-90 Pontiac 6000
88 Pontiac Fiero
87-95 Pontiac Grand Am
91-93 Pontiac Grand Prix
88-93 Pontiac Le Mans
92-94 Pontiac Sunbird
96-01 Pontiac Sunfire
90-95 Pontiac Transport
4L30E – Automatic​
YEAR MAKE MODEL
97-01 Cadillac Catera
05 Chevrolet Aveo 4DR Hatchback (China)
04-05 Chevrolet Aveo 4DR Hatchback
05 Pontiac Wave 4DR Hatchback
4L60 – Automatic​
YEAR MAKE MODEL
92-93 Buick Roadmaster
91-93 Buick Roadmaster Estate Wagon
90-92 Cadillac Brougham
93 Cadillac Fleetwood Brougham
83-86 Chevrolet Berlinetta
83-93 Chevrolet Camaro
85-93 Chevrolet Caprice
91-93 Chevrolet Caprice Station Wagon
87-93 Chevrolet Corvette
85 Chevrolet Impala
91-92 Oldsmobile Custom Cruiser Station Wagon
83-93 Pontiac Firebird
85-86 Pontiac Parisienne
92 Chevrolet/GMC Blazer 1/2-ton K 4WD
87 Chevrolet/GMC Blazer/Jimmy 1/2-ton V 4WD
92 Chevrolet/GMC Blazer/Jimmy T 4WD
87-91 Chevrolet/GMC Full-size 1/2-ton R 2WD
88-91 Chevrolet/GMC Full-size 1/2-ton V 4WD
87 Chevrolet/GMC Full-size 3/4-ton R 2WD
88-92 Chevrolet/GMC Pickup 1/2-ton C 2WD
88-92 Chevrolet/GMC Pickup 1/2-ton Ext Cab C 2WD
92 Chevrolet/GMC Pickup 1/2-ton Ext Cab K 4WD
87-92 Chevrolet/GMC Pickup 1/2-ton K 4WD
87 Chevrolet/GMC Pickup 1/2-ton R 2WD
88-92 Chevrolet/GMC Pickup 3/4-ton C 2WD
88-92 Chevrolet/GMC Pickup 3/4-ton Ext Cab C 2WD
92 Chevrolet/GMC Pickup 3/4-ton Ext Cab K 4WD
88-92 Chevrolet/GMC Pickup 3/4-ton K 4WD
87 Chevrolet/GMC Pickup 3/4-ton R 2WD
91-93 Chevrolet/GMC Pickup S 2WD
91 Chevrolet/GMC Pickup T 4WD
87-92 Chevrolet/GMC S10/S15 S 2WD
87-92 Chevrolet/GMC S10/S15 T 4WD
92 Chevrolet/GMC Suburban 1/2-ton C 2WD
92 Chevrolet/GMC Suburban 1/2-ton K 4WD
87 Chevrolet/GMC Suburban 1/2-ton R 2WD
87-92 Chevrolet/GMC Van 1-ton G
87-92 Chevrolet/GMC Van 1/2-ton G
92 Chevrolet/GMC Van 1/2-ton Passenger G
87-92 Chevrolet/GMC Van 3/4-ton G
90-92 Chevrolet/GMC Van Astro/Safari L AWD
87-92 Chevrolet/GMC Van Astro/Safari M 2WD
92 GMC Yukon 1/2-ton K 4WD
4L60E - Automatic​
YEAR MAKE MODEL
94-96 Buick Roadmaster
99-04 Cadillac Escalade EXT ESV 1/2-ton C 2WD K 4WD
94-01 Chevrolet Camaro
94-96 Chevrolet Caprice
95 Chevrolet Caprice Classic
94-01, 03-04 Chevrolet Corvette
02-04 Chevrolet Avalanche 1/2-ton C 2WD K 4WD
03-04 Chevrolet SSR Sport Truck S 2WD
95-04 Chevrolet Tahoe 1/2-ton C 2WD K 4WD
02-04 Chevrolet TrailBlazer 4DR EXT S 2WD T 4WD
94 Chevrolet/GMC Blazer/Jimmy S 2WD
93-94 Chevrolet/GMC Blazer/Jimmy T 4WD
04 Chevrolet/GMC Colorado/Canyon Pickup S 2WD
04 Chevrolet/GMC Colorado/Canyon Pickup T 4WD
93-04 Chevrolet/GMC Pickup 1/2-ton C 2WD K 4WD
01-02 Chevrolet/GMC Pickup 1/2-ton Crew Cab K 4WD
93-02 Chevrolet/GMC Pickup 1/2-ton Ext Cab C 2WD K 4WD
93-04 Chevrolet/GMC Pickup 3/4-ton C 2WD K 4WD
93-04 Chevrolet/GMC Pickup 3/4-ton Ext Cab C 2WD K 4WD
93-04 Chevrolet/GMC S10/S15 S 2WD T 4WD
94-04 Chevrolet/GMC Suburban 1/2-ton C 2WD K 4WD
93-99 Chevrolet/GMC Van 1-ton Express/Savana G
93-04 Chevrolet/GMC Van 1/2-ton Cargo Express/PassengerExpress/Savana G
93-04 Chevrolet/GMC Van 3/4-ton Cargo Express/PassengerExpress/Savana G
93-04 Chevrolet/GMC Van Astro/Safari L AWD M 2WD
02-04 GMC Envoy 4DR EXT XUV S 2WD T 4WD
95-04 GMC Yukon 1/2-ton C 2WD K 4WD
04 GMC Yukon XL 1/2-ton C 2WD K 4WD
03-04 HUMMER H2
96-01 Oldsmobile Bravada T 4WD
96 Oldsmobile S15 S 2WD
94-01 Pontiac Firebird
04 Pontiac GTO
4L80E - Automatic​
YEAR MAKE MODEL
01 Chevrolet/GMC Cab Chassis K 4WD​
99-01 Chevrolet/GMC Pickup 1-ton C 2WD​
99-01 Chevrolet/GMC Pickup 1-ton Crew Cab C 2WD
01 Chevrolet/GMC Pickup 1-ton Crew Cab K 4WD
99-00 Chevrolet/GMC Pickup 1-ton Ext Cab C 2WD
01 Chevrolet/GMC Pickup 1-ton Ext Cab K 4WD
01 Chevrolet/GMC Pickup 1-ton K 4WD
01 Chevrolet/GMC Pickup 1/2-ton C 2WD
01 Chevrolet/GMC Pickup 1/2-ton Crew Cab C 2WD
01 Chevrolet/GMC Pickup 1/2-ton Crew Cab K 4WD
01 Chevrolet/GMC Pickup 1/2-ton Ext Cab C 2WD
01 Chevrolet/GMC Pickup 1/2-ton Ext Cab K 4WD
01 Chevrolet/GMC Pickup 1/2-ton K 4WD
99-01 Chevrolet/GMC Pickup 3/4-ton C 2WD
99-01 Chevrolet/GMC Pickup 3/4-ton Crew Cab C 2WD
01 Chevrolet/GMC Pickup 3/4-ton Crew Cab K 4WD
99-01 Chevrolet/GMC Pickup 3/4-ton Ext Cab C 2WD
01 Chevrolet/GMC Pickup 3/4-ton Ext Cab K 4WD
01 Chevrolet/GMC Pickup 3/4-ton K 4WD
01 Chevrolet/GMC Van 3/4-ton Cargo Express/Savana G
01 GMC Yukon 3/4-ton K 4WD
99 Chevrolet Tahoe C 2WD
99-01 Chevrolet Tahoe K 4WD
95-99 Chevrolet Tahoe 1/2-ton C 2WD
91-01 Chevrolet/GMC Cab Chassis C 2WD
91-99 Chevrolet/GMC Chassis 1-ton P
96 Chevrolet/GMC Chassis Delivery Cutaway P
94-03 Chevrolet/GMC Chassis Delivery P
96 Chevrolet/GMC Chassis Motor Home Cutaway P
94-03 Chevrolet/GMC Chassis Motor Home P
96-04 Chevrolet/GMC MD Isuzu Truck Forward
96-97 Chevrolet/GMC MD Isuzu Truck Tiltmast
91-03 Chevrolet/GMC Pickup 1-ton C 2WD
92-99 Chevrolet/GMC Pickup 1-ton Crew Cab C 2WD
91 Chevrolet/GMC Pickup 1-ton Crew Cab V 4WD
92-99 Chevrolet/GMC Pickup 1-ton Ext Cab C 2WD
93 Chevrolet/GMC Pickup 1-ton Ext Cab K 4WD
93 Chevrolet/GMC Pickup 1-ton K 4WD
91-93, 95-96,
00-03 Chevrolet/GMC Pickup 1/2-ton C 2WD
95-96 Chevrolet/GMC Pickup 1/2-ton Ext Cab C 2WD
91-04 Chevrolet/GMC Pickup 3/4-ton C 2WD
99 Chevrolet/GMC Pickup 3/4-ton Crew Cab C 2WD
92-99 Chevrolet/GMC Pickup 3/4-ton Ext Cab C 2WD
92-94 Chevrolet/GMC Pickup 3/4-ton Ext Cab K 4WD
91-94, 04 Chevrolet/GMC Pickup 3/4-ton K 4WD
95-99 Chevrolet/GMC Suburban 1/2-ton C 2WD
99-01 Chevrolet/GMC Suburban 1/2-ton K 4WD
99-04 Chevrolet/GMC Suburban 3/4-ton C 2WD
92-03 Chevrolet/GMC Suburban 3/4-ton C 2WD
91-93, 01 Chevrolet/GMC Van 1-ton Cargo G
93-96, 01 Chevrolet/GMC Van 1-ton Commercial/RV G
96-03 Chevrolet/GMC Van 1-ton Express/Savana G
91-96 Chevrolet/GMC Van 1-ton G
96-03 Chevrolet/GMC Van 3/4-ton Express/Savana G
99 GMC Yukon C 2WD
99-01 GMC Yukon K 4WD
00-04 GMC Yukon XL 3/4-ton C 2WD
4T40/45E - Automatic​
YEAR MAKE MODEL
95-04 Chevrolet Cavalier​
97-04 Chevrolet Malibu​
97 Oldsmobile Achieva
99-04 Oldsmobile Alero
97-99 Oldsmobile Cutlass
99-04 Pontiac Grand Am
95-04 Pontiac Sunfire
4T60 - Automatic​
YEAR MAKE MODEL​
88-93 Buick Century​
88-90 Buick Electra​
88-91 Buick LeSabre
88-90 Buick Reatta, Riviera
88-92 Buick Regal
88-90 Cadillac DeVille
88-90 Cadillac Eldorado
88-90 Cadillac Fleetwood
88 Cadillac Fleetwood Limousine
88 Cadillac Funeral Coach
89 Cadillac Hearse/Limo Conversion
88-90 Cadillac Seville
88-90 Chevrolet Celebrity
90-92 Chevrolet Lumina
89-91 Oldsmobile 88 Royale
88-92 Oldsmobile Cutlass
88-93 Oldsmobile Cutlass Ciera
88 Oldsmobile Delta 88 Royale
88-90 Oldsmobile Ninety-Eight Regency
88-90 Oldsmobile Toronado
88-90 Oldsmobile Trofeo
88-91 Pontiac 6000
88-91 Pontiac Bonneville
88-92 Pontiac Grand Prix
4T60E - Automatic​
YEAR MAKE MODEL
94-99 Buick Century​
92-97 Buick LeSabre​
91-96 Buick Park Avenue
91 Buick Reatta
93-99 Buick Regal
91-93, 95-96 Buick Riviera
94-98 Buick Skylark
91-95 Cadillac DeVille
91-93 Cadillac Eldorado
91-93 Cadillac Fleetwood
91-93 Cadillac Seville
94-96 Chevrolet Beretta
95 Chevrolet Corsica
91-99 Chevrolet Lumina
92-96 Chevrolet Lumina APV
95-99 Chevrolet Monte Carlo
97-98 Chevrolet Venture
92-97 Oldsmobile 88 Royale
94-98 Oldsmobile Achieva
91-98 Oldsmobile Cutlass
94-96 Oldsmobile Cutlass Ciera
97 Oldsmobile Cutlass Supreme
91-97 Oldsmobile Ninety-Eight Regency
92-98 Oldsmobile Silhouette
91-92 Oldsmobile Toronado
91-92 Oldsmobile Trofeo
95 Pontiac 88 Royale
92-97 Pontiac Bonneville
94-98 Pontiac Grand Am
91-99 Pontiac Grand Prix
92-98 Pontiac Transport
4T65E - Automatic​
YEAR MAKE MODEL
97-04 Buick Century​
98-04 Buick LeSabre​
97-04 Buick Park Avenue
97-04 Buick Regal
03-04 Buick Rendezvous
97-99 Buick Riviera
00-01, 03-04 Chevrolet Impala
97-01 Chevrolet Lumina
97-04 Chevrolet Monte Carlo
99-04 Chevrolet Venture
97-99 Oldsmobile 88 Royale
01 Oldsmobile Aurora
98-01 Oldsmobile Intrigue
97-99 Oldsmobile Ninety-Eight Regency
99-04 Oldsmobile Silhouette
01-04 Pontiac Aztek
97-04 Pontiac Bonneville
97-04 Pontiac Grand Prix
99-04 Pontiac Montana
98-99 Pontiac Sunfire
4T80E - Automatic​
YEAR MAKE MODEL​
93 Cadillac Allante
94-96 Cadillac Concours
94-04 Cadillac DeVille
93-01 Cadillac Eldorado
93-04 Cadillac Seville
95-03 Oldsmobile Aurora
03-04 Pontiac Bonneville
5L40E​
YEAR MAKE MODEL​
02-05 Cadillac CTS​
5LM60 - Manual*
YEAR MAKE MODEL
85-02 Chevrolet Camaro​
89-02 Chevrolet Corvette​
91-93 Chevrolet Lumina
92-94 Oldsmobile Achieva
91-92 Oldsmobile Cutlass
85-02 Pontiac Firebird
92-94, 00 Pontiac Grand Am
00-02 Pontiac Sunfire
02-04 Cadillac Escalade EXT 1/2-ton C 2WD
02-04 Cadillac Escalade EXT 1/2-ton K 4WD
02-04 Cadillac Escalade EXT 3/4-ton C 2WD
02-04 Chevrolet Avalanche 1/2-ton K 4WD
02-04 Chevrolet Avalanche 3/4-ton C 2WD
94 Chevrolet Blazer S 2WD
94 Chevrolet Blazer T 4WD
02 Chevrolet Tahoe 1/2-ton C 2WD
01-02 Chevrolet Tahoe 1/2-ton K 4WD
02 Chevrolet Suburban 1/2-ton C 2WD
01-02 Chevrolet Suburban 1/2-ton K 4WD
01-02 Chevrolet Suburban 3/4-ton C 2WD
91-02 Chevrolet/GMC Cab Chassis C 2WD
91-95, 97-99 Chevrolet/GMC Chassis Delivery P
91-00 Chevrolet/GMC Full-size 1-ton K 4WD
92-02 Chevrolet/GMC Full-size 1/2-ton C 2WD
02 Chevrolet/GMC Full-size 1/2-ton Crew Cab C 2WD
02 Chevrolet/GMC Full-size 1/2-ton Ext Cab C 2WD
92-00 Chevrolet/GMC Full-size 1/2-ton K 4WD
97-99 Chevrolet/GMC Low Cab Forward
91 Chevrolet/GMC Pickup 1/2-ton C 2WD
01-02 Chevrolet/GMC Pickup 1/2-ton Ext Cab K 4WD
91, 01-02 Chevrolet/GMC Pickup 1/2-ton K 4WD
89-95 Chevrolet/GMC Pickup S 2WD
94 Chevrolet/GMC Pickup T 4WD
93-02 Chevrolet/GMC S10/S15 S 2WD
93-02 Chevrolet/GMC S10/S15 T 4WD
85-88 Chevrolet/GMC Van Astro/Safari M 2WD
02 GMC Yukon 1/2-ton C 2WD
01-02 GMC Yukon 1/2-ton K 4WD
01-02 GMC Yukon 3/4-ton C 2WD
Discussion Starter #18
v8sdyme said:
my 2.2l 95 s-10 came with a WC b&w t-5
:rotf: :bs: why would a 2.2 be backed by a world class tranny
and blazee thats some good info maybe now this post can be stickied
It would be a world class because they stopped making non-world class ones. I looked according to hollinger's interchange, both 94 and 95 2WD 2.2's had them
Discussion Starter #20
why put a world class tranny behind a 2.2
1 - 20 of 32 Posts
