Alright I need some tranny removal tips. Truck is a 84 Blazer 4x4. I can't reach the top two tranny to engine bolts. I wanna know if its possible to pull the tranny and engine at the same time. Any tips are appreciated guys.
Stef
use a long extenstion w/ an deep inpact swival socket. pulling the motor to get the trans out sounds like alot more work then is nessesary.
take off all your bodymounts and lift the body a inch or two.:thumbup: works great!
I agree, but the motor was coming out anyway.
T/A drivin foundin member
how would you guys be planning on doing that?
theres a lot of crap in the way with 4x4, hell we had a tough time just getting the oil pan to cleart the crossmember
When i yanked mine i had the rad rib out the transfer case off and the body lifted 4" and i still messed up my heaterbox cover. but it came out!
removing the front clip helps alot and saves the panales from a new spray job. ive helped afreind do this but i think he had a bodylift at the time we pulled it ....but im not sure.
