1 - 2 of 2 Posts
has anyone had a problem with draggin through their transmission hard line, right by the exhaust under the truck? mine just happend to hit the ground and leaked all the fluid out and the truck wont go anymore. How hard is it to replace this line. I have a 99 with the 4.3
Vandelay Industries
I would go to the junkyard and get a used line. otherwise if you buy new line at the parts store you get to bend it yourself. all you need to change it is the right size line wrench. unscrew it from the trans and the radiator and fish it out. Make sure you get the new one put in high enough that it wont drag. You can manipulate those lines by hand if you are careful.
1 - 2 of 2 Posts
