hey whats up guys had a ? when i engage the 4hi button it sounds like the transfer case is engaging but no four wheel drive i can jack the front end up and spin the front wheels and the front shaft spins with them. I figured if it was in four wheel drive the front shaft would not spin, had a friend tell me there is forks in the case and one could be split?
weird my truck pops the tranny out of 4 hi into 2 wheel have you tried in 4 low
id say its in the t-case then
And you have checked the 4x4 actuator? You spin the wheels up front and the driveshaft should spin, but if the actuator isn't engaging it wont lock your front-end and make it seem like your t-case isn't shifting. Does it shift into low?
