NOW TUCKIN' 20'S
ok heres the deal, im running my hornblasters kit threw 2 different valves, the bigger horns on one and the smaller 2 horns on the other so i can have 2 different tones. anyways im running either 1/2 or 3/4 in. valves and lines. i was wondering if anybody had done both and seen a difference in sound. if they 3/4 doesnt improve the horns im gunna just go with 1/2 sense i have fittings and stuff already.
any advice would be good, also i was thinking about using this valve
http://cgi.ebay.com/ebaymotors/GC-Xtreme-3-4-250-psi-valve-for-air-ride-suspension_W0QQcmdZViewItemQQcategoryZ42609QQitemZ8058607453QQrdZ1
but idk if GC is a good brand, never tried them.
They took our jorbs.
gc is an ok valve, ive heard of some people have problems, others swear by them. Anyways, you shouldnt be able to notice a diffrence. The horns only pass a certain amount of air with time (cfm rate).
NOW TUCKIN' 20'S
ya i didnt know what the CFM rating was on them. probably just run the 1/2 and regulate it down sense ill have about 250 psi in it
I think the flow rate on the 4 horns combined is slower than that of any 3/8" or larger valve, so I don't really think you're doing anything other than wasting money. If it wasn't, then you would hear a definate change in horn pitch due to the pressure drop. If the horns consume, let just say for grins, a total of 20cfm, and anything larger than a 3/8" valve flows at least 160cfm at 125psi, then regardless of the size valve you use, the horns will still only consume 20cfm at 125psi.
