Ok guys I know its not an s-10 but I was needing some help, and it seems that you all are the best forum around. I am just needing a vauge description of a traditional body drop and how to do it.
Thanks for the help
well having a 69 c-10 myself, BD on that style of a truck is faily easy what i did was cut the pinch off and then lowered my cab mounts 1 inch theres clerance under the cab, so nothing will hit.... for the front just drop the frame horns do to match. depending on tire size you'll have to Z the frame or section the front crossmember, to get the front on the ground and notch the back. pm me if you have futher questions... also try www.69-72chevytrucks.com
