ALMOST DONE
what does everyone with a tpi setup use for a upper hose to the thermostat?? the neck comes straight out and the hose wont fit between the alternator and radiator..i just ordered a new 90 degree therm. neck so i can run the hose behind the alt. and into the radiator..anyone who has pics or ideas please post so i can get this thing running
RFG Customs
I actually used the stock 2.5 4 cyl upper rad hose.fit good with the stock tpi thermostat housing.
ALMOST DONE
yeah mine wont work like that..the alternator is right there...i figured it out though..i hadda buy a new thermostat neck and route the line behind the alternator...i hadda cut the throttle linkage off and grind down some screw heads on the throttle body
