2000 s-10 4.3 (auto) 4wd ex cab. No rust, no codes, 110,000 miles.
Once I replace my fuel pump and I feel good about everything running well for awhile, I’d like to tow. Based on the diff code and owners manual, it says my tow limit is 5,900lbs.
One is a ski boat at about 3200lbs with trailer.
The other we haven’t obtained yet is a travel trailer, probably about 4000lbs.
It’s decently hilly here, Pacific Northwest, and I’m wondering about others’ experience with towing. It’s not terribly hot, except for maybe 1 week a year, and a lot of the towing would be in autumn and spring, maybe winter even.
I have a hitch currently and will probably go for the distribution hitch for the travel trailer at least.
I was thinking an aftermarket trans cooler and trans temp gauge as well (any suggestions?)
Thanks!
Premium Member
As far as pulling that weight you’ll be fine, stopping the weight is another story, a trailer brake controller would be high on my list, trans cooler never hurt.
Especially going down hill.
Most states require trailer brakes on trailers the weigh over 3000#.
Reactions: Frank Bukowski
Thanks- fun story I was looking underneath it and noticed that there were two drops of bright green coolant hanging on the bottom of the bell housing- I’m assuming this is most likely a LIM gasket leak in the back and I should get prepared to change it?
Add a cooler to your transmission, you're going to work it hard. HEAT is the transmission's #1 enemy.
700R4's and early 4L60Es didn't like to tow at all in OD, it would burn 'em up in less than a hundred miles.
