UnderDawg
Discussion Starter #1 (Edited by Moderator)
4x4 1/4" tube fits in side the frame rails drilled and tap in bolts top and bottom of frame, and then welded. used receiver insert with clevises, cut in from the back to fit and then cut the front to fit. no way it's coming off without the frame still attached
UnderDawg
haven't got to the front yet, frames different, will post picture when I do that, receiver is bolted (big as self tappers) and welded. parts are shelf items, got mine from menards. was thinking I might be able to make a tilting tire carrier , mounting we're the clevises are.
