Are there a heavier rate torsion bars that came in S10s from the factory? If not who makes some good ones? I put this in the V8 section because when i swap in a 350, i don't want the ride height to go down. By that time the torsion bars will be cranked to the max so i can run 31s.
:evilg: :scary:
Go to the GM dealer and have them pull up a set of Olds Bravada Torsion bars. It will tell max pressure. Then have them look up the bars on your Blazer. I would think the Bravada ones are higher pressure. If you find they are and you need a set, I just pulled the set out of my wife's Bravada to put in my Typhoon Torsion bars so I could lower it to the stock Typhoon height.
Good idea, i really don't want the front end to lower when i put in the 350. i'll check it out at my local gm dealer, i might even be able to get them on a discount. I'd imagine that heavier shocks would also be in order. Thanks :idea: :evilg:
