Wannabe Dragger
Yup, AutoZone's repair section on their website probably does. A Hayne's manual might, if you can trust that.
Bearing Caps = 60 lb. ft.
Pinion Nut = 12-15 lb. in. with NEW crush sleeve
Pinion Nut = 6-7 lb. in. with OLD crush sleeve
**Note the Pinion nut is in INCH pounds
Ring Gear Bolts = 55 lb. ft.
Backlash = 6-10 (.001 inch)
I'm slap happy, bitches!
is that pinion nut setting rotational torque?
if you torque that nut with the sealant on the threads to only 20 inch lbs, the pinion bearings arent even gonna last long enough to go to the store and get beer after completing a job like this.
if you are going to post data figures for tightening torques, please clarify.
the 60 ft lbs on the carrier caps bolts is right though.
make sure the bolts are clean, and there isnt any gear lube in the holes, and lube the bolt threads with a spray of wd-40 or something.
goin broke but n style
ring gear bolts are reverse threaded.
