1 - 11 of 11 Posts
2Low2Tow
TORQUE SPECIFICATIONS-1994-2001 CHEVY S10’s & GMC SONOMA’s
**Ft-lbs (Unless otherwise indicated)**
FOR 1994-2001 CHEVY S10’s & GMC SONOMA’s
**ALL TORQUE SPECS ARE PER GM FACTORY & HAYNES MANUAL**
2.2L FOUR CYLINDER ENGINE:
Camshaft sprocket bolt 96
Camshaft thrust Plate bolts 106 in-lbs
Crankshaft Pulley to Hub Bolts 37
Crankshaft Pulley to Crankshaft bolt 77
Connecting Rod Cap Nuts 38
Crankshaft Main Bearing Cap Bolts 70
Crankshaft Sensor 97 in-lbs
Coolant Drain plug- Cylinder Block
*(Driverside of Engine block-below Freeze plugs) 11
Coolant Pump 18
Coolant inlet bolts 18
Coolant Outlet Adapter Bolts 89 in-lbs
Coolant Outlet Nuts 89 in-lbs
Electronic Ignition System Coil Assy 18
EGR Valve Nuts 12
EGR Valve Adapter Bolts 97 in-lbs
EGR Valve Solenoid Bolt
*(Which is mounted between upper 22
intake manifold and fuel rail under TPS Sensor)
Engine Coolant Temp Sensor 106 in-lbs
Engine Lift Bracket Nut/Bolt 37
Exhaust Manifold Nuts 115 in-lbs
Exhaust Manifold Studs 89 in-lbs
Exhaust Pipe To Manifold Nuts 18
EVAP Emissions Canister Purge Valve Nuts 18
Fly Wheel Bolts- AUTOMATIC TRANSAXLE 55
Fly Wheel Bolts- MANUAL TRANSAXLE 55
Fuel Injector Retainer Bolts 15
Fuel Outlet Pipe to Fuel Pressure Regulator Nut 21
Heater Hose Fitting-Upper Intake Manifold 24
Intake (Lower) Manifold Nuts (thru 1998) 24
**1999+Later Torque Nuts and Bolts to 17**
Intake (Lower) Manifold Studs 89 in-lbs
Intake (Upper) Manifold Bolts 22
Knock Sensor 14
Map Sensor 27 in-lbs
Oil Fill Tube Nut 106 in-lbs
Oil Filter Connector 26
Oil Filter ¾ to One turn after gasket “Oring” contact
Oil Level Sensor 16
Oil Pan Nuts & Bolts 89 in-lbs
Oil Pan Drain Plug 33
Oil Pan Studs 89 in-lbs
Oil Pressure Sensor 115 in-lbs
Oil Pump Cover bolts 89 in-lbs
Oil Pump Drive Assy. 18
Oil Pump Mounting Bolt 32
Oxygen Sensor 31
Pressure Plate Bolts 28
Cylinder head bolts:
STEP 1: LONG BOLTS 46
SHORT BOLTS (Exhaust manifold side) 43
STEP 2: Tighthen ALL BOLTS an additional 90 degrees
Engine mount-to-engine bolts 39
Engine mount through-bolts 38
Engine mount bracket-to-frame bolts 33
Lifter Guide retainer-to-block stud 97 in-lbs
Oil Pan bolts 89 in-lbs
Oil Pump-to-block bolt 32
Rocker Arm Studs 37
Rocker-arm nuts (Bolts on 1999 and later) 19 to 22
Timing Chain cover bolts 97 in-lbs
Timing Chain Tensioner Torx Style Bolts 18
Sparkplugs 13
Valve Cover bolts 89 in-lbs
Accelerator Cable mounting Bracket 18
Accessory Bracket Assy. to Block 37
***EVEN THOUGH THE 4.3 TORQUE SPECS BELONG IN THE
262ciforum, I didn’t want our big brothers to feel left out*** :02redxbla
4.3L V6 Engine Ft-lbs (Unless otherwise indicated)
Valve cover bolts:
1994 and 1995 90 in-lbs
1996 On 106 in-lbs
Intake manifold bolts
1994 and 1995
VIN Z (SEE ILLUSTRATION)
All, except bolt 7 in intial tightening sequence 35
Bolt 7 41
**Bolt 7 becomes bolt 6 in final tightening Sequence.**
Intake manifold torque sequence-4.3L (VIN Z) throttle body fuel injection
VIN W (FOR ALL INTAKE MANIFOLD BOLTS) 35
1996 On (See illustration For Intake Manifold Tightening Sequence)
Step 1: 26 in-lbs
Step 2: 106 in-lbs
Step 3: 132 in-lbs
Exhaust Manifold bolts/studs
Step 1: 132 in-lbs
Step 2: 22
Cylinder Head Bolts
1994 and 1995 65
1996 On (See illustration)
Step 1 (All bolts): 22
Step 2:
Short bolts Tighten an additional 55 degrees
Medium Bolts Tighten an additional 65 degrees
Long Bolts Tighten an additional 75 degrees
Timing chain cover bolts
1994 124 in-lbs
1995 On 106 in-lbs
Camshaft Sprocket Bolts 21
Balance Shaft retainer bolts 106 in-lbs
Driven gear bolt
Step 1: 15
Step 2: Tigthen an additional 35 degrees
Drive gear retaining stud 144 in-lbs
Rocker Arm nuts (bolts on 1999 and later) 20
Vibration damper bolt 70
Hydraulic Lifter retainer bolts 144 in-lbs
Oil Pan
1994 and 1995
Bolts 100 in-lbs
Nuts 204 in-lbs
1996-1998
Bolts 204 in-lbs
Nuts 216 in-lbs
1999 and later (All) 18
Oil pump Bolt 65
Rear main oil seal retainer bolts 132 in-lbs
Flywheel/drive plate bolts 75
2Low2Tow
Discussion Starter #2
Re: TORQUE SPECIFICATIONS-1994-2001 CHEVY S10’s & GMC SONOMA’s
The illustrations I had listed with 4.3 specs aren't showing will try to make a 2nd attempt to post them shortly.
2Low2Tow
**First Picture is the tightening sequence for VIN Z 4.3L Intake Manifold Bolts 1994-1995**
**Second Picture is for 1996 & Newer-Intake Manifold Tightening Sequence**
**Third picture is for the tightening sequence of Cylinder head bolts on 1996+Newer models.
What is the torque value on the tensioner bolt on a 98 s10 2.2? I have the Haynes repair manual and it doesn't say..
It would also be nice to correct the mis guided Haynes and store bought chiltons manual on torque specs for the pinion shaft yoke to u joint strap "bolts". Their book says 180 ft. lbs of torque which i know cannot be right. I have already busted off 3 bolts in the past attempting this (and yes they were all grade 8 or higher bolts). With those size bolts...your lucky to see 75 ft. lbs before they twist and break.
Premium Member
The Haynes book says "180 inch lbs"... Thats only about 15 lbs/ft. ??? Confused???
Brain fart here...it was late last night when i read this.
I need to know the torque specs on the fuel meter body to tbi body those three little bolts. because I broke the front bracket on my fuel meter body and don't want to do it again.
Can someone help me please?
In the process of rebuilding my 2.2L, anybody know where I can find replacement hardware for engine and attaching hardware for components?
Sent from my iPad using Tapatalk
1 - 11 of 11 Posts
About this Discussion
6 Participants
Slickdeezy562
S-10 Forum
Full Forum Listing
