Self Portrait
My torque converter clutch (TCC) is not locking up most of the time. Every once in a while it will lock up (once a month at highway speeds of about 62mph.) I have looked in all the manuals I can get my hands on and I can't find any information on how to test to see if the trans is actually getting the signal from the ECU. The trans is a 700r4/4L60 (1992, 4.3L) they have the same scheme to lock up the clutch.
Does anyone know how the test the lock-up signal from the ECU to the trans to tell the TCC to lock?
Any help would be great!
Thanks in advance!
Rick
'92 S-10 Tahoe 4.3L Bone Stock
usually its the lock-up selenoid or the convertor itself. havn't ran across the ecm not giving the signal yet, but it is possible. if you drop the pan , take out the harness w/ the seloniod any tranny shop should be able to check it for you in a matter of a minute. air check the selonoid and a current test and you you will have found youre problem( most likely) or narrowed it down to two possibilities.
Self Portrait
Thanx for the info!
I'll know what to ask for when I take it in!!
