54S : CHEVROLET
Primary Color Code: 382E : Pewter Metallic PRIMARY COLOR:
11U : EXTERIOR COLOR,PRIMARY TRIM COMBINATION:
12H : TRIM COMBINATION CLOTH, GRAPHITE TRIM COMBINATION:
12I : INTERIOR TRIM GRAPHITE PACKAGE/SALES PACKAGE:
1SA : PACKAGE-OPTION 01 FINANCIAL PROGRAM / FLEET PROCESSING:
1SZ : PACKAGE OPTION- COMPONENT FRONT LEFT:
6ZZ : SPRING COMPTR SELECT FRT LH COMPONENT FRONT RH:
7ZZ : SPRING COMPTR SELECT FRT RH SEAT:
AM6 : SEAT,FRONT SPLIT,3 PASSENGER WITH CENTER ARMREST FLOOR COVERING:
BG9 : COVERING,FLOOR(RUBBER) GVW RATING:
C5A : GVW RATING(4900 LBS) HVAC SYSTEM / INTERIOR HEATER:
C60 : AIR CONDITIONER,FRONT,MANUAL CONTROLS MIRROR O/S:
D44 : MIRROR,OUTSIDE,BELOW EYELINE(PAINTED) EQUIPMENT -:
DNR : EQUIPMENT DEALER INSTALLED BODY EQUIPMENT:
E63 : BODY EQUIPMENT,FLEETSIDE PICKUP BOX TEST:
EVA : TEST DVT, EVAP EMISSION REQUIREMENT CERTIFICATION:
FE9 : FEDERAL EMISSION CERTIFICATION AXLE REAR:
GU6 : AXLE,REAR,3.42 RATIO BOOSTER:
JM3 : BRAKE BOOSTER,DOUBLE DIAPHRAGM HIGH FLOW(240MM) GENERATOR:
K60 : GENERATOR,100 AMPERE ENGINE:
LU3 : ENGINE GAS, 6 CYL, 4.3L, MFI, V6, 90 DEG TRANSMISSION:
M30 : TRANSMISSION,AUTOMATIC 4 SPEED,4L60E,ELECTRONIC STEERING:
N40 : STEERING,HYDRAULIC(NON-VARIABLE) EMISSION SYSTEM:
NT9 : EMISSION SYSTEM FEDERAL, TIER 2 PHASE-OUT FINANCIAL PROGRAM / FLEET PROCESSING:
PDZ : CONTROL SALES ITEM NO. 142 WHEEL:
PH1 : WHEEL,15X7(STEEL) TIRE ALL: QCE : TIRE ALL- P205/75R15/N BL R/PE ST TL ALS FINANCIAL PROGRAM / FLEET PROCESSING:
R6J : CONTROL SALES ITEM NO. 10 FINANCIAL PROGRAM / FLEET PROCESSING:
R9Z : CONTROL - SALES ITEM NO. 100 RESTRAINT:
RSA : RESTRAINT FRT SEAT, 208, AUTO, PASSIVE PLANT CODE:
SLA : PLANT CODE SHREVEPORT,LA, GMT&B SALES PROCESSING:
SLM : SALES PROCESSING-STOCK ORDERS LAMP SYSTEM:
T61 : LIGHTING,DAYTIME RUNNING FINANCIAL PROGRAM / FLEET PROCESSING:
TFE : SALES INCENTIVE COMMITMENT PLUS ANTENNA:
U73 : ANTENNA,FIXED RADIO:
UM7 : RADIO,AM/FM STEREO,ETR,CLOCK AUDIO SYSTEM PROVISIONS:
UP8 : RADIO,PROVISIONS FOR STEREO INSTRUMENTATION VEHICLE STATEMENT:
V73 : VEHICLE STATEMENT - US/CANADA BUMPER:
VF6 : BUMPER,REAR STEP TRAILER HITCH:
VR4 : TRAILER HITCH(WEIGHT DISTRIBUTING PLATFORM) VEHICLE APPLICATION:
VXS : LABEL COMPLETE VEHICLE TIRE FRONT:
XCE : TIRE FRONT P205/75R15/N BL R/PE ST TL ALS TIRE REAR:
YCE : TIRE REAR P205/75R15/N BL R/PE ST TL ALS (9591039) AXLE REAR:
YD3 : AXLE FRONT (BASE EQUIP) FOR SCHEDULING GVW PLATE SPEAKER SYSTEM:
YD5 : SPRING,FRONT(BASE EQUIPMENT) SPRING REAR:
YD6 : SPRING,REAR(BASE EQUIPMENT) CHASSIS PACKAGE:
Z85 : CHASSIS PACKAGE,INCREASED CAPACITY MARKET BRAND:
Z88 : GMC TRUCK TIRE SPARE:
ZAA : TIRE,COMPACT SPARE COLOR COMBINATION:
ZY1 : COLOR COMBINATION SOLID
Wheel Base (Inches): WBI#117.9 : 117.9 Wheel Base (Metric): WBM#299.5 : 299.5
Engine Designation: 4732 : LU3 Engine VIN: 30 : X Valves: 2 : 12 CC: ECC#- : - CID: ECD#262 : 262 Liter: ENL#4.3 : 4.3 Engine Bore (Inches): EBR#4.00 : 4.00 Engine Bore (Metric): EBM#101.6 : 101.6 Engine Stroke (Inches): EST#3.48 : 3.48 Engine Stroke (Metric): ESM#88.4 : 88.4 Cylinders: CYL#6 : 6 Fuel Delivery Sub Type: 5 : MFI Fuel Delivery Type: 5 : FI Fuel System Control Type: 5 Fuel System Design: 45 : Central SFI Aspiration: 5 : Naturally Aspirated Cylinder Head Type: 7 : OHV Fuel Type: 5 : GAS Ignition System Type: 5 : Distributor-Breakerless Engine Manufacturer: 11 : General Motors Engine Version: 8 : Vortec Power Output (Horse Power): PHP#190 : 190 Power Output (Kilowatt Power): PKW#142 : 142 Body Number of Doors: 7 : 2 Body Type: 17 : Standard Cab Pickup Engine Block Type: BLT#V : V
