hey there....
if you want to go low....the lowest drop without problems would be a 5/6-7 drop.....I'm on stocks still =( and have this drop. It will rub bad before an allignment, but once it's alligned it's cool....I have a full radius turn with no rubbin'....if ur intrested in this drop let me know.... =0)
chickentheS10
The most you'll be able to do and no rub bad is a 3/4 drop. Otherwise you'll be hitting the top of the inner fenders.
chickentheS10 - with your 5/6 drop, do you still have stock 205-75-15 tires? There is no way in hell you go that low and not rub anything. With my 4/5 drop and zq8 wheels/tires, which are an inch shorter, I still rub on the inner fender thru dips. Your tire would be resting on the fenders. Or are you using stock wheels and smaller tires?
hi there....actually i do have a 5" drop in the front and 6" or 7" drop in the back....on stock tires and wheels. I will hit the inner fenders once in awhile on dips....but no I'm not resting on the fenders....
yes....it was rubin' bad, but that was before the alignment...
