im putting a 2.5in rough country lift on my 01 Blazer whats the largest tire i can use im seeing alot with 31's wondering if 32's would work
Which wheels are you planning to use - the 15x7 stock rims, or something else? Tire size/ wheel size compatibility is a factor.im putting a 2.5in rough country lift on my 01 Blazer whats the largest tire i can use im seeing alot with 31's wondering if 32's would work
The rims I'm using are 15x8 also if i have to trim for the 32's I'm not against itWhich wheels are you planning to use - the 15x7 stock rims, or something else? Tire size/ wheel size compatibility is a factor.
