I have a 2.2L 2wd Sonoma with an open differential and am looking to get a little better traction out of it. I don't do anything crazy with it, but tired of getting stuck when there's just a little bit of a slick spot. One option I could do would be to put in a limited-slip differential of some sort. Another option would be to go with a more aggressive tire and get better at applying the brakes slightly when one of the wheels is slipping. I'm mainly looking to get better traction in the winter and to be able to drive across a field to pick up a deer a couple of times a year. I know the best option would be to get a real truck with 4wd, but I don't have the money for that now.
What are your thoughts on better tires vs limited slip differential for improving traction? If your vote is for a limited slip differential, should I go torsen or posi?
If I go the tire route, I've heard good things about Goodyear Wrangler Duratrac tires. The trouble is that the smallest size they have are 235/75R15. I think they should fit on stock 2wd rims, but how bad will they rub the frame when turning? Another could be Firestone Destination A/T, and they come in the stock 205/75R15 size. They also seem to be about 1/2 the price of the Duratracs.
Going with both tires and a new differential might be the next best option short of real 4wd, but I don't have the money to do both right now.
