I have a 2002 S-10 2wd with factory tires, 205/75-15 i was wanting to make the truck ride alittle better and set slightly higher, so it does not sag in the rear end. What are some recomendations of tire sizes i should use, i still want to use my original 15 rims. And without screwing up my gear ratio to much. thanks for your help
Project: Sabriel
changing tires wont really make you sit higher...maybe 1/2" if that. and rear end sag is not something corrected by tires - you need to get longer shackles, or an add-a-leaf kit.
