When I set timing on my 88 2.8 TBI do I need to have the air filter and and Map sensor installed. I timed it without and it runs fine but as soon as I attach the sensor it runs rough and stalls out.
Do map sensors tend to fail I think I may need to replace mine.
Pushrod for life!
yes the map needs to be hooked up, but the filter can be left off
Pushrod for life!
no just take off the clip that holds it to the assembly
life begins @ 20 psi
Don't forget about this wire either:
"The ESC Electronic Spark Timing "tan wire with a black stripe" that everyone can't find when attempting to set their timing (s-series). Wire is under the carpet on the passenger side below the heater box. It is disconnected to set the timing, then reconnected."
News to me. Thanks for the info
