1 - 15 of 15 Posts
CNC Plasma Cutting
Have a project that I am bidding on and if I get it, I'll be able to factor in a new welder. This project will be completely out of stainless, probably 304. I have watched someone tig on numerous occasions, but I have not done any tig welding myself. So with that said, do you guys have any suggestions on a tig machine? I don't need it to do anything over, say 1/4"-3/8". I've been looking online at millers, but I'm not apposed to other makes if you have had good success with it. Thanks :D
Dems 22s
Ive only used one tig, and its a miller syncrowave 250 dx. I use it a lot and i love it. They are really expensive, but its worth the money, and with your custom work, it would eventually pay for its self. It has high frequency so you can weld aluminum also
The Vehicle Dynamics Bro.
buy a dynasty.... cheaper to run, and more consistent.
The new Dynasty's are ridiculous. If I was gonna purchase a TIG welder today I would get the latest model Dynasty 350 without a doubt. 10 minutes of seat time with any other welder and ten minutes with the newer model Dynasty and you'll know why - especially if you were doing aluminum work.
http://store.cyberweld.com/mitigwedy3501.html
extremlove
miller is the only tig i have ever used. kinda expensive but if you are going to do alot of tiggin then you might as well go ahead and buy a good set up and not have to worry about is screwing up a year from now.
CNC Plasma Cutting
Thanks for the suggestions fellas... I'll most likely be going with a Miller. Couple of the metal working forums I'm on also recommended Miller. Just need to decide which model to go with and how much of my profit I want to trade for buying a welder. This will be one of my biggest projects to date (almost $20k).
another good tig to look in to is the thermal arc 186 AC/DC very nice machine and fraction of the price.
Miller Diversion is a very good starter tig if you want AC
If you dont plan on doing aluminum you dont need AC which will make it alot cheeper.
badmat have you ever ran a syncrowave or a dynasty???
your right about the power because dynasty is a inverter
but consistancy of what compaired to welding with a syncro
im going to buy the miller 180 tig here soon. it has a nice price and is a 220 unit that can do aluminum. i weld stainless everyday for a living and we use a little portable miller maxstar 150 stl. its only a 110 unit but the new version has the option of using 110 or 220 plugs. it wont do aluminum though is its only down fall for me but is portable and good for traveling. ive done had ours all over the country. in its case its the size of a small suit case and can get checked in with you luggage at the air port. check out the miller 180 tig though its what i plan to buy for home use
the diversion 180 is perfect for the at home shop.
Lincoln (square wave I think) 175 is pretty good too but older style, cheaper tho
Call me Mario, Princess
I have a diversion 180 and love it. I work in a fab shop that does a lot of welding with dynastys and syncrowaves and have had some of the welders come over and they really like my welder. It is good for 3/16 single pass and anything bigger than that just need some extra passes.
Premium Member
Ordering a Miller Diversion 180 in the next few days. First project will be an exhaust system for my LSX Blazer. Been a while, but I really enjoyed using a TIG welder many years ago, so look forward getting back up to speed. This model is made in USA, correct?
i love my miller diversion 180. best of both worlds can use 110 or switch plug end to 220 when need the extra heat. also being able to go from ac/dc is nice. i mainly do 316 stainless with it but on occasions i use it for aluminum. works great for me and i use it daily atleast 4 hours a day. also i got the add on pedal, i need to learn the hand control for the times its a pain to use a pedal
Premium Member
Just got mine set up, using a 80 CF 100% Argon (I think the supplier called it a "Q" size ??) at any rate he traded me straight up for a 30 year old Acetylene tank I had which was cool since I expected to pay for a new tank. You are quite right about that nice feature of the 180 with the ability to simply swap an adapter plug to use either 115V or 230v. Lining up a bunch of mild steel and ss plate and tubes to get back up to speed on my welding skills. Fun stuff.
1 - 15 of 15 Posts
