it is seperate and MSD makes it specifically for their boxes, i can get the part numbers for both the box and harness off of summit if you want.sweetbutxtreme said:the wiring harness......do you think it would come with the MSD ignition or would I have to buy it separate and if so what/who would you suggest?
the helix bore corrects the air flow and spirals it to make it a lil less turbulent. there was a difference when i put it on.:thumbup:clone said:i dont think you will see a diff with a throttle body spacer because thet mix the air fuel up better before it goes into the comb chamber, and your truck shoots the fuel directly into the comb chamber. but still go for the msd, get a msd coil also.
well i'll prolly get more of an improvement from the MND and all that right........is there a site where can i get that wiring harnness and the coils?MightyMouseJ5 said:
is there one that would work best....sorry for all the questions but i have no clue bout this oneMightyMouseJ5 said:
i am partial to summit, but jegs is the same exact thing. i do buy from both. i would check out both and compare prices, the box might be cheaper from one, but the harness or wires might be cheaper from the other.:thumbup:sweetbutxtreme said:
i havent bought it yet, but i am gonna get the MSD GM Blaster Coil. should be like $35 to $50 bucks i believe.:thumbup:sweetbutxtreme said:i was wondering what coils are better? sorry for not making it clear. i did notice tho that on one of those sites, the MSD 6A was $50 cheaper than another site i was gonna get it from so thanx already for that
took the words right out of my mouth!:thumbup:sweetbutxtreme said:thanx on behalf of me and mm
