Third brake light tinted? How to remove?
907 Views 4 Replies 5 Participants Last post by  Gen210
My Sonoma I recently bought has tint on the third brake light, the headlights were tinted with some spray on stuff and that was pretty easy to remove but I can’t seem to remove the tint on the third brake light. I don’t think it’s film, and I tried to wet sand it with steel wool and some water and it just made it hazy but still tinted.
how do I go about removing this?
Not knowing what the material is makes for a challenging 'correct' answer. It is possible that the lense is an aftermarket "smoked" type, where the coloration is intergral to the plastic. IF it is an oil based spray on product, perhaps try using acetone, or mineral spirits (turpentine) - separately, and try a small test area first. Another solvent might be Goof Off. If none of those are successful, you may be looking at a simple light lense replacement. There are plenty of online sources and the cost won't break the bank.
Agree with aitch. Sounds like the tint is integral to the plastic, so replacement is the best option....plastic lens shouldn't be expensive. If it is on the surface, then sometimes Goo Gone and or WD40 are good for removal. The steel wool might remove the offending exterior substance, but it scratches the lens leaving it hazy. Even if that succeeds with tint removal, you would then have a new job to polish the lens to get rid of the haze.
get a new lens
Reactions: 1
Much cheaper and easier to replace
