I just cummed.
:wtf: Does anyone else have a problem with their third brake light? I tried to locate a fuse for it but couldn't find any. I also tried like 4 sets of good bulbs up there. I'm afraid I will have to tear my headliner out and check the connection. Is there an easier way to find the problem????? Or does anyone else have similar problems?
Yeah... mine has problems sometimes, I just hit it and it works for a while again... I don't really care, I'm putting LED's in there in a couple of days. But if yours it the same problem as mine, it is getting power back there, but the rivets are corroded and don't make contact w/ the clip that holds the light. I would take a multimeter and check the voltage at the rivet on the bottom coming through the cab, and then check it at the clip that holds the light bulb.
DogP
I just cummed.
I hope its still covered by the warranty. I put bulbs covered with engine enamel spray paint and a clear lense over it. Does this neccesarily void the warranty? THe man at the dealership told me not to worry about it he has it covered. I hope this is the case.
