1 - 15 of 15 Posts
LS6 swap in progress.
1999 LS6 Sonoma on C5 Brakes
Hey everyone
just wondering if you changed thermos, what temp are you running and why. Im thinking about changing mine from stock (~195) to somthing lower. I've heard lowering it decreases gas mileage, though, but just wondering what others have done.
Thanks!
AJ
95 S-10 2200
I have a 195 and I can't get the truck to warm up to that temp anyway. I'm gettin about 23-25mpg right now. I know that before I replaced the head with everything stock I was getting 25-28.
The doctor is in...
You can't go any lower then 180* because your computer is going to freak out if you don't hit 179* with in a time span (don't know what the length is). Mine sits at about 185* on the highway and 210* in traffic. My e-fan is set to 190* so usually my fan is off (unless the AC is on) when I'm driving down the highway. I haven't seen any changes in my mpg. That is probably because I live in Houston and my engine is almost at stock temperature in traffic.
My truck overheats in traffic if I turn the ac on. I installed 3 E-fan (2 pullers 1 pusher) and a 180 degree thermostat, still the temperature goes thru the roof if I turn the ac on in traffic and goes down as soon as I turn it off. I even remove the thermostat, same problem, I beginning to think the something is wrong with the ac or the temperature sensor. By the way I notice the difference without that big and heavy clutch fan, in this trucks anything help.
The doctor is in...
Had a similar problem, noticed you had an Xtreme. Seems to be an issue with air flow on these trucks. What solved it for me was the Flex-A-Lite Black Magic fan.
child at heart
ditto here except i'm in dallas. i run my 180* ststat in the summer to help with the cooling but the a/c condenser is the problem, it's just a big heater in front of the radiator.
child at heart
tiny ass radiator is the problem especially with an auto pumping hot fluid through it too, i'm thinking about a separate cooler for the trans.
The doctor is in...
Yeah, I forgot about you auto guys. This humidty here in Texas really kicks our butts.
I have two 10 inch zirgo fans pulling and one 9 inch pushing. However I did noticed how thin the radiator is during the installation. In the old days you could take it to a radiator shop and they could double the capacity.
freeze!
yah now I have this problem in gillette wy too if I turn my ac on in traffic it over heats and its on like 70 here I have a 16" fan and a 10" fan but it still does this can any one tell me why? any suggestions?
The doctor is in...
The biggest issue is that people don't take into consideration the amount of air (CFM) that is moved by the fan. Also, there is a huge improvement withe the help of a fan shroud. That is why when I went to the Black Magic by Flex-A-Lite my over heating issues went away.
It is a bit high compared to most of the cheap fans, but it will do the job RIGHT. Your other option might be to consider the LS1 fans.
Discussion Starter · #13 ·
yeah ive got an e-fan from a junk yard and it's worked well. i only had one time last summer when the temps got around 215 and thats when my AC was on...got pretty scared when i saw that gauge up that high, but after i turned off the AC all was well.
Thanks for the replies,
AJ
i have stock thermostat and im guessing its a 195... i dont think i have ever seen mine go over the 210 mark... even when i was crossing Rogue valley in oregon in the summer it never went over...
The doctor is in...
The stock setup will run around 210* most of the time. Last year on my way to S-Series Nationals we were passing through Dallas with 98* temps and 90% humidity and I was seeing 210 to 215 while sitting in traffic and 200 while moving.
When we hit Kansas and Missouri we were seeing 96* temps and I was running at about 190* through there. Humidity has a lot to do with engine cooling. :(
1 - 15 of 15 Posts
