Just wondering how to change the thermostat. its the first one ive had to change so im not quite sure on how to. mine is staying open and its not warming mine engine like it should. any info will help thanks
Yes, it is about the easiest thing you will do. A little bit of coolant will come out. Make sure you put the gasket on the new one, it might come with one. It is at the front of the intake manifold, you can follow the upper rad hose to it. I'd tell you exactly where it is, but i have no idea what motor you have.elegantSdime said:thanks. i think all i do is pop the 2 screws off and drop the new in right?
