81 - 100 of 132 Posts
· Boozebag
Discussion Starter · #82 ·
Weird... I used a combination of AN fittings.
Some eBay, Jegs and Summit. I have a large box full of fittings from many different projects
I haven't had any problems yet.
· Boozebag
Discussion Starter · #83 ·
Motor vehicle Hood Bumper Automotive tire Automotive exterior
AN adapters
Tire Wheel Automotive tire Motor vehicle Tread
Stainless lines
Automotive tire Automotive fuel system Motor vehicle Automotive exterior Automotive wheel system
Not a great pic, but there is a brass "T" fitting there.
Motor vehicle Automotive fuel system Automotive air manifold Gas Auto part
You can see the AN -4 stainless line looping back to return line of the stock system. The middle of the "T" feeds the Weber through a 3/8" see through fuel filter. You can see the filter fill as the carb needs fuel, when the carb bowl is full, the fuel flow stops.
The system works very well. I was going to install a fuel pressure gauge, but it doesn't seem to need it.
· Boozebag
Discussion Starter · #84 ·
After I installed the disc rear end, I tried to bleed the brakes - no go.
It seems like the truck had no rear brakes for a long time.
Rectangle Luggage and bags Bag Snow Fashion accessory
Here's the reason ^^^
I don't know why, but GM added rear anti lock brakes??? (brilliant idea - but uh, NO)
The ABS control valves were stuck, not allowing any fluid to pass by.
Solution?
Yep, eliminate.
Plenty of fluid to the rear calipers.
The first time out for a test ride almost sent me through the windshield.
The brake pedal is much higher and is lots firmer. I barely apply pressure and the truck stops HARD....
All it took was 1 5/16" brake line union.
· Boozebag
Discussion Starter · #85 ·
Wood Automotive tire Motor vehicle Bumper Gas
It's time...
Motor vehicle Automotive tire Automotive fuel system Automotive exterior Bumper
No danger any more
Motor vehicle Vehicle Hood Automotive exterior Automotive tire
Cleaned out the old brown juice and installed fresh DOT 4 synthetic fluid. Flushed the entire system too.
Ma, the brakes work...
· Boozebag
Discussion Starter · #86 ·
Automotive fuel system Hood Motor vehicle Automotive design Automotive tire
Completely installed Weber and Edelbrock performance intake manifold.
The engine starts instantly in any weather and idles. Plenty of power,all vacuum components are connected and working.
It runs better than the TBI it replaced - hard to believe.
Motor vehicle Automotive exterior Gas Automotive wheel system Bumper
A little creativity for the throttle connection. Works surprisingly well
o_O
· B4U Task Force
o_O
Looks like you're missing a bolt...
1995 S10 2.2 liter 5 Speed 2wd RCSB
I am missing a bolt.
Just lost my way...
I'll be back
I used to have access to all of the AN fittings I could want! (Aircraft Mechanic) as long as the new stuff went in the aircraft we could have the old fittings.
Now they all have to be tagged and destroyed.
From Long Island, I get called Yankee every day at work! Lol it's all good!
Reactions: Mad Max
· Premium Member
I love all of your crap sir. Thanks again for the bolts!!! Let me know if you need any weird parts I may have laying around.
MadMax, You're Close to me, about 130 miles(Close?) Come on over to Augusta.
Reactions: ProCycle
· Boozebag
Discussion Starter · #98 ·
^^^ Thanks for the invite!
I was working 7 days/week, 10 hour/days.
Then? The bottom dropped out. I'm back in Baton Rouge - FTW.
Working for Unkle Sam is crazy sometimes.
I anticipate being back there at some point, if it happens I will def look you up.
· Boozebag
Discussion Starter · #99 ·
Pro - Didn't have enough time to source anything new...
At least I can finish this project.
I think I mentioned that a friend has claimed this rig. He's sent $$ already, so this is going North.
I've done most of the mechanical stuff, now it's on to interior crap.
Carpet, sound dead stuff, radio, speakers, rebuild the bench seat, and more.
I guess either he'll be flying here or I'll drive it North packed with parts and a full trailer.
More pix and improvements coming
