Since the whole droppin' it section seems to be cluttered with trucks of all different drops, i wanted to put this together for future reference and personal enjoyment.
Rules:
Must be at least 5/6 or lower
list your suspension mods/products
post tire size
6 3/4 drop all around from factory with tire size included. belltech spindles, and springs in the front (rides on bumpstop) and belltech 3" springs, 2.75" custom machined blocks, and 3/8" set back plate I believe. low rider depot mini notch welded in.
18x8 235/40/18 front, 18x9.5 275/35/18 rear
picture of the rear fitment... hella flush?
soda can
had to wedge it under the valance, just barely too low to clear it
Didn't have to because I have a small wheel and tire combination. My lower arms aren't all jacked up at shitty angles like ones with bigger wheels might be. I actually still have a cut-down rubber stop in the front to stop my wheels from colliding with my inner-fenders.
Dropped 5.5"/6" on 205/55/15's all around.
Front: 4 cylinder 3" DJM springs, Belltech spindles, Belltech shocks and de-humped and plated lowers with a modified factory bump stop on the plated section.
Rear: Belltech springs, 3" angled blocks, air shocks and an AAC bolt-in notch.
Sooner than later I will be buying Power Performance tall lower ball joints and 4" block for the rear.
It still gets used as a truck as well, I have a trailer hitch hidden behind the plate, and the air shocks help immensely.
